Orbi WiFi 7 RBE973
Reply
New router can’t connect to orbi
Mshep1234
Message 1 of 5
Mshep1234
Re: New router can’t connect to orbi
I am going through setup wizard and get stuck when it tries to connect to orbi it says unable to connect
Message 2 of 5
Guru
We need more details.
1. What orbi model do you have?
2. What "new router" are you connecting to it?
3. what modem/gateway do you have?
4. How are you actually setting it up? Are you connecting the orbi to a gateway and then the new router to the orbi or some other method.
Details are key
Message 3 of 5
Mshep1234
Hi it’s the rbr50 v2
We have just had the latest virgin media hub 4 installed. Orbi was working great before then.
We have the orbi connected to the new hub 4 router from virgin. Thanks!
Message 4 of 5
Guru
The virgin hub 4 has its own integrated routing functions. That can put you in a double nat.
couple things you can do to fix it. (only use 1 method)
1. put the vigin hub in modem only/passthrough mode. It disables its router function. Contact your isp for help with this.
2. put the netgear in access point mode. disables a few features on the orbi but leaves wireless and ethernet working.
3. put the netgears ip address into the virgin hubs dmz.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 567 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
