- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
No Attached Devices after updating to firmware V2.5.1.8
- Mark as New
- Bookmark
- Subscribe
- Permalink
After upgrading to firmware V2.5.1.8 Router no longer shows ANY attached devices, not satellites nor other devices, WiFi and Wired alike.
Have 4 satellites RBS50, 2 x RBS40, RBS20
Rebooting all systems has no change.
Have not done a factory reset on everything yet, I have a moderately involved set-up and have not wanted to take the hours to rebuild everything or rely on backup restoring correctly.
All devices are working on the network, just not showing up in the router's attached devices list. Same results from both the browser interface and the Orbi App on Android.
Anyone else have this problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: No Attached Devices after updating to firmware V2.5.1.8
Some users have reported this issue with the iOS app, is that what you are using? If so, check the web interface to see if the devices appear there. There is a separate board on the community forum for the applications, so check it if you are seeing the same issue for the iOS app. I use v2.5.1.8 on my RBR50/RBS50 setup and the Android app and web interface shows all the devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Also try a factory reset:
https://www.youtube.com/watch?v=cMw4ePACgc4
https://www.howtogeek.com/434350/how-to-factory-reset-a-router/
Good Luck.
@Cynomus wrote:After upgrading to firmware V2.5.1.8 Router no longer shows ANY attached devices, not satellites nor other devices, WiFi and Wired alike.
User | Count |
1 | |
1 | |
1 | |
1 | |
1 |
