- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
No Internet on Orbi WiFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you try accessing your modem page? most likely something like http://192.168.100.1 from there you can change its settings, do you have a device that can connect to the Orbi Network directly via Ethernet cable? also sometimes the issue where a specific device cannot get internet access is resolved by just making the specific device forget the Wi-Fi network, this can be done on the device's Wi-Fi setup settings, then once it has forgotten it try connecting to it again, you will again need to enter your password etc.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: No Internet on Orbi WiFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad I was able to help, I would also suggest you to just disable Wi-Fi on your modem if it also broadcasts a Wi-Fi network in your house, the Orbi's network will be faster and more reliable anyways, you will also have less interference in your home.
