Reply
No Internet via LAN
WayneU
No Internet via LAN
I own a NETGEAR Orbi Pro AC3000 Business Mesh WiFi System, 2-Pack, Wireless Access Point (SRK60) and cannot access the internet via ethernet hard-wired LAN. I have a multitude of wireless devices that can access the internet just fine via the Orbi. My desktop computer is a MAC Pro running High Sierra 10.13.6, and I also have a MacBook Pro running the same person of High Sierra. These computers can connect to the internet using WiFi, but if WiFi is turned off, then there is no internet available via LAN.
Devices that are hardwired to the LAN are able to communicate with each other (for example, one can access shared disks across the LAN, or can print to the LAN printer). But I am totally at a loss as to why I suddenly cannot simply use my LAN without WiFi to connect to the internet through the Orbi Pro.
My LAN card does not have any hard-coded DNS, or Search Domains.  TCP/IP IPv4 is configured with a fixed manual address using DHCP.
The Orbi Satellite has nothing connected to any of its Ethernet ports.  The Router firmware version is V2.2.1.210.
I welcome any suggestions.
Model: Orbi Pro Tri-band WiFi System (SRK60) AC3000
Message 1 of 3
Guru
Re: No Internet via LAN
You'll need to post this here:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-orbi-pro
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK50 v2.7.2.104(WW) Circle, DST and Traffic Meter>Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 3
WayneU
OK.  Thank you.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 587 views
  • 0 kudos
  • 2 in conversation
Announcements
