Reply
No color on satellite on startup - dead unit?
JanMoelbach
Follower
Hi,
I just bought this system. The router works well, but I just can't seem to get anything working on the satellite.
When I power it on, the power LED turns green, and then nothing happens. The "ring" LED doesn't do anything. If I try to factory reset the satellite, I believe the power LED is supposed to blink amber or something, but it just stays solid green after holding down the reset button for up to 1 minute.
Do you think my sattelite unit is dead?
(I have also tried different power outlets, all with the same result)
Message 1 of 3
Ely
Luminary
Luminary
Re: No color on satellite on startup - dead unit?
I would go to the store and  get an exchange.
Message 2 of 3
DarrenM
Sr. NETGEAR Moderator
Hello JanMielbach
Yea you might want to swap the unit if possible if not contact Netgear support.
http://www.netgear.com/support/contact.aspx
DarrenM
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1808 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
