Orbi WiFi 7 RBE973
Reply
No devices connected to the Satellite
varun8211
Follower
I have Orbi  model # - RBR40.
I have 2 satellites connected. But none of my devices connect to them. They always stay connected with the main router. Shouldn't my devices automatically connect to the satellites if the devices comes close to the satellite?
Can someone help?
Message 1 of 2
SW_
Prodigy
Prodigy
Re: No devices connected to the Satellite
It's often the case when there's strong signal overlapping/interference within the same area of coverage.  A simple solution is to reboot/power cyle the device in question.  If the device is running into trouble because of weak signal and won't connect to nearby Satellite after reboot, you can check out this workaround.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 619 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
