Orbi WiFi 7 RBE973
Reply
No improvement in WiFi with Orbi RBK50
SusanOrbiRBK50
Follower
Just purchased & installed Orbi RBK50
Situations:
App does not run speed test, WiFi the same as with Dlink router
Have LUS Fiber 100x100
Do I have a bad router or should I just return & go back to dlink.
Reviews were great,  real results not even close
Any suggestions.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 3
loomis1975
Luminary
Re: No improvement in WiFi with Orbi RBK50
Are you saying that you possibly have a BAD ROUTER because its performance equals a D-Link router that is performing as expected?
I don't know what D-Link router you are trying to compare the Orbi to, but Orbi is generally used to get better Wi-Fi throughout a home, i.e. eliminate dead or slow spots, by having the a router and satellite(s) offer better coverage area in a large space.  If a single router is giving good performance in all areas of your home, I'm not sure why you would want to go from a single router solution to a router and satellite pseudo-mesh solution.
Not sure what your results are.  But on a 100 down / 100 up internet connection with Orbi, you should be seeing all of your up and down speed on any single ethernet connected device (as long as its not an old "fast" ethernet port) and on any single 802.11AC wireless device.
I would try with the Ookla Speednet App from windows store on Windows 10, or Mac at http://www.speedtest.net/apps/desktop
or for mobile at http://www.speedtest.net/mobile
Message 2 of 3
Guru
What is the Mfr and model # ISP modem the Orbi router is connected too?
What FW version is currently loaded on the Orbi system?
Situations:
Any suggestions.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 684 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
