Orbi WiFi 7 RBE973
Reply
No longer can use Bluetooth with PC
wesleyrm
Tutor
Hello,
I recently installed an Orbi Router and satellite. RBR50 firmware 2.5.1.8.
It’s affecting the Bluetooth connection on my PC and not allowing me to connect my headset or mouse. I’ve never run into this issue before with a router or 2.4ghz. Checking online, I tried some solutions such as changing the channel for the 2.4ghz band. However this did not solve the issue.
Can anything be done to solve this issue? The satellite is in the same room as my PC, but if I turn it off and try connecting to the router, which is downstairs, I still have the same issue.
Message 1 of 6
Accepted Solutions
Guru
Re: No longer can use Bluetooth with PC
You can try lowering the power output of the RBR if needed and you think the Orbi is effecting your BT devices. Under Advanced Tab/Advanced Settings/Wireless Settings
@wesleyrm wrote:
Hello,
Message 3 of 6
All Replies
CrimpOn
Guru
I have no doubt there is a problem with the PC bluetooth connection.  Doubt very much it is the Orbi.  I regularly sit three feet from my Orbi with all sorts of bluetooth devices having a merry time. What happens when ALL of the Orbi devices are turned off?
Message 2 of 6
Guru
@wesleyrm wrote:
Hello,
Message 3 of 6
wesleyrm
Tutor
Once I turn off the orbi devices and use the stock router that came from my ISP the BT with my PC works again.
Message 4 of 6
wesleyrm
Tutor
@wesleyrm wrote:
Hello,
Thanks! I dropped 2.4Ghz to 75% and my BT on PC now works and connects to devices again.
Message 5 of 6
Guru
Glad that worked.
Enjoy.
@wesleyrm wrote:
@wesleyrm wrote:
Hello,
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1244 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
