- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Not getting a strong 5ghz signal from Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an Orbi pair with RBR50 and RBS50. The Guest wifi is booming through at 5GHz but the private wifi seems to be weak in areas. Having done some analysis it seems as though one of the units isn't transmitting the private network on 5GHZ as can be seen from the attached picture (Guest network seen at -46dB [Strong] and -78dB [Medium] but Home only seen at -77dB [Medium]). You can see that all signals are visible at 2.4GHz. Does anyone have any ideas?
Yours, Tom
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Not getting a strong 5ghz signal from Orbi
@TomBertie wrote:I have an Orbi pair with RBR50 and RBS50. The Guest wifi is booming through at 5GHz but the private wifi seems to be weak in areas. Having done some analysis it seems as though one of the units isn't transmitting the private network on 5GHZ as can be seen from the attached picture (Guest network seen at -46dB [Strong] and -78dB [Medium] but Home only seen at -77dB [Medium]). You can see that all signals are visible at 2.4GHz. Does anyone have any ideas?
Yours, Tom
Probably issues with the firmware - what firmware do you have?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@TomBertie wrote:
Both units have the current firmware: V1.12.0.18
I would have to suspect that the buggy firmware has something to blame with this - V2 for the firmware has no ETA and could be weeks away - I would try and a different channel for 5gh or see if you are having any interference from neighbors WiFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
disable the guest wifi and see if the main wifi on 5 gig comes back
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your results look strange. Wherever you were when you made this measurement, you were seeing very weak signals on 2.4 GHz for both the router and your satellite. That would indicate poor coverage in that test location. Yet, you show -46 for the guest on 5 GHz. That doesn't make sense at all.
I'd suggest moving positions and repeat the measurement. If you suspect one of the units is not broadcasting one of the SSIDs, then move close to that unit and test.
Also, you should only be using channels 1, 6, or 11 for 2.4 GHz, so I'd recommend changing channel settings there as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
