- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI 20 slow speed on 2,4G
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all!
Just replaced my AIMesh system with ORBI AC2200 due to AIMesh instability. Decided to keep one ASUS Router as router and has setup the ORBI RBR20 as an AP. Everything runs well and smooth on the 5GHz band with speeds around 240 Mbit/s (which is close to may internet speed 250/250). But on 2,4 Ghz band I only gets around 20-25 Mbit/s. If I activate the 2,4G on my ASUS router I get around 100 Mbit/s with 40 MHz bandwidth. I have also noticed that ORBI stays at 20 MHz bandwidth whatever I try in configurations. Any hints?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya if you only have 2 RBS, you can disble Daisy Chain.
Glad it's working well now. Please mark your thread as solved so others will know.
Enjoy.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI 20 slow speed on 2,4G
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Reboot both Orbi system and wireless device your testing with.
Try a different wireless device to test with to compare...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi and thank for respons!
Using latest firmware.
Apprx 90 sq meters.
Distance approx 10 meters
Currently ch 11.
WiFi Neighbors 3 visible in WiFi analyzer at <-80dBm.
I have finally solved the problem and has now approx 100 Mbit/s on 2,4 Ghz. Did a factory reset on both router and sattelite and a new installation from start using the WEB Gui. My setup is as follows:
AP mode
Circle disabled
Guest disabled
Coexistense 20/40 disabled
WMM enabled
Daisy chain enabled (could be disabled I guess as I only have one sattelite)
Implicit beamforming enabled
MU-MIMO enabled
Fast Roaming enabled
With above setup 2,4G now runs smoothly with 40 MHz bandwith and approx 100Mbit/s throuput.
So problem solved!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
