- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI 40
- Mark as New
- Bookmark
- Subscribe
- Permalink
ORBI 40
ORBI of course streams extremely well to all my systems except for the Direct Tv. My DVR and main Hub is hard wired to internet. However, my receivers are wireless in the other rooms. This is where the freezing occurs.
Thanks for any help provided.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI 40
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
