Reply
ORBI AC3000
rbaron
Tutor
ORBI AC3000
I watch videos on YouTube regarding setting up an ORBI. I see the speed test that the installer does after installing and setting up the ORBI. Some of the speeds are excellent, like, 214mbs or higher.
When I did my speed test after installing my ORBI, I am getting 19.81mbs down. and 1.45 up.
So my question is, if I am paying my ISP (Centurylink) for a 20mbs connection, is that all I will see on my speed tests with my ORBI?
Thanks in advance...
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Guru
Re: ORBI AC3000
Would seem to be near what you should be getting.
I would test with a wired PC using a web browser pointed to speedtest.net as a 2ndary test as well.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.223/SRK30 V3.2.33.106)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, RBK50, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 200 views
  • 0 kudos
  • 2 in conversation
Announcements
