Orbi WiFi 7 RBE973
Reply
ORBI APP
rdabbah00
ORBI APP
Hi my app do no show my conected devices , i unistall it and intall again and doesnt work
i need to acces my orbi using my computer
Message 1 of 12
Guru
Re: ORBI APP
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
Message 2 of 12
SLK-Purdue
Luminary
Re: ORBI APP
I suspect this is actually the SOAP problem I reported with FW 16 and not the app.  The app is getting bad data.
scott
Good Luck.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 3 of 12
rdabbah00
Re: ORBI APP
What you mean SOAP problem? i dont undestarnd that
Message 4 of 12
CrimpOn
Guru
Re: ORBI APP
I believe SOAP refers to this:
https://searchapparchitecture.techtarget.com/definition/SOAP-Simple-Object-Access-Protocol
It's a mechanism to query the Orbi router for information.  The Orbi "app" communicates with the Orbi router, asks for information, and does things with it (such as display icons, etc.)
Message 5 of 12
SLK-Purdue
Luminary
Re: ORBI APP
Sorry.  I should have provided more background. SOAP is the method that the app uses to get data from Orbi. Per my previous posts, I believe the problem is that Orbi is giving incorrect data to the app rather than an actual problem in the app. I had some issues with the new app too but I have an Excel spreadsheet that can make SOAP calls directly to Orbi.   The data from Orbi is incorrect.
Scott
Message 6 of 12
Guru
Re: ORBI APP
Have you contacted NG support about this?
Scott
Message 7 of 12
SLK-Purdue
Luminary
Re: ORBI APP
Yes
Message 8 of 12
SLK-Purdue
Luminary
Re: ORBI APP
Support told me to try the old firmware! LOL
Message 9 of 12
Guru
Re: ORBI APP
Smiley Tongue
Awesome.
You might pass this on to a forum moderator. @Blanca_O and @Christian_R. Hopefully they can pass this on to NG engineering.
Message 10 of 12
tantrum
Apprentice
Re: ORBI APP
I similarly lost all devices from the (iOS) app a couple of days ago.
Noticed they would still show up in the web interface on a computer.
Turns out the web interface makes / receives JSON calls, and the app makes/receives SOAP calls with an XML payload.
My AVR is a Denon and when I switched it on, the device manufacturer name was automatically read in as "D&M Holdings" and a bare "&" character (not escaped as an XML entity like "&") is disallowed and breaks the parsing of the response.
I changed the manufacturer name and applied it in the web app, and now the iOS app can show them all again fine.
In case it helps anyone seeing the same behavior, thought you may want to check into it.
To troubleshoot/debug, if you need to, use a computer with Fiddler (by Telerik) running on it, tell it to run in proxy mode over its normal port of 8888, then set the wifi properties in your iOS device to a manual proxy and give it the IP and 8888 port of the computer.
Fiddler on the computer will now capture the request/responses sent by the phone (the app sends in plain http to the local routers so don't have to worry about https certs) and you can inspect them.  If you use its XML view of the inspector tab, it will even tell you which line the parsing breaks at, or you can copy/paste the response to something like Notepad++ which can also parse the XML and tell you what is bad.
Message 11 of 12
Guru
Re: ORBI APP
Good Luck.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 2127 views
  • 2 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
