Orbi WiFi 7 RBE973
Reply
ORBI Android App does not find my ORBI units
askg
My RBR40 router S/N 50K1745V0038E with a wall plugin satellite is not discovered by the Orbi app in my mobile. It used to find them before I upgraded firmware in both router and satellite.
The App is version 2.2.0.363
Best,
/Gösta Ask
Model: RBK52W| Orbi Router + 2 Wall-Plugs Orbi WiFi System
Message 1 of 4
Guru
Re: ORBI Android App does not find my ORBI units
Message 2 of 4
FightingFurball
It may be that your phone is connecting to a different Wi-Fi network.  Verify that your phone is connected to the SSID of your Orbi.
Message 3 of 4
askg
Hi FightingFurball,
My handset is certainly connected to the Orbi router network, using the SSID that is published. The same that my computers use. From one of them I read
  Aktuell nätverksinformation:
Simris:
  PHY-läge: 802.11n
  BSSID: 9c:3d:cf:21:72:41
  Kanal: 36,1
  Landskod: DE
  Nätverkstyp: Infrastruktur
  Säkerhet: WPA2 Personal
  Signal/brus: -51 dBm / -90 dBm
  Överföringshastighet: 300
  MCS-index: 15
And the Wifi in the handset uses SSID Simris
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 600 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
