Discussion stats
  • 1 reply
  • 335 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
ORBI DISCONNECTS SEVERAL TIMES PER DAY --- DOS ATTACKS
Not sure if this is DOS attack related but I've experienced ongoing problems with dropping connection for the past month (maybe since the last update?) when I scan the log it shows im being hit with numeorus DOS attacks continuously.  The DOS attacks, I suspect, are causing dropped connection.  Anyone have a fix for this?
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 2
Highlighted
Guru
Re: ORBI DISCONNECTS SEVERAL TIMES PER DAY --- DOS ATTACKS
What modem Mfr and model# are you using?
Cable or DSL?
Where are you seeing these DOS attacks?
Is the disconnects seen on the client side or router side? WIreless disconnects?
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK853 v3.1.15.32(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, RBK50, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 2
