Reply
ORBI Hair Pinning Bug
den452001
I have a server that unable to access external IP Addresses when connected to LAN.
For example External Ip Address: 108.111.111.222
Internal Ip Address. 192.168.1.100
When connected to the same network, Internal IP works, but external IP Won't work. However using the same device server , external ip works.
When i'm outside with other networks, External IP Works Flawlessly.
Device: ORBI RBR850 Server: Ubuntu 20.04
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
Guru
Re: ORBI Hair Pinning Bug
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK853 (Router Mode) | and R9000 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, R9000, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
Message 2 of 5
CrimpOn
Guru
(connecting to Sprint... oh, my)
  • Can any other computer on the LAN connect to this IP address?
    If so, the problem may be with Ubuntu (perhaps a Firewall setting?)
  • What kind of connection is this? (ftp, http, dns, ntp, telnet, ssh.....?)
I love my Orbi.
Message 3 of 5
den452001
Hi, crimpon thank you for your reply.
Every computer able to accces the LAN ip from LAN network.
Just normal HTTP connection, i tried ssh too, no budge.
Message 4 of 5
CrimpOn
Guru
I may be confused about the "direction" of connection. I see two possibilities:
  • This server is trying to make an http connection from the Orbi LAN to an external IP address (such as 108.111.111.222) but cannot
    Every other computer on the LAN is able to make an http connection to 108.111.111.222.
  • This server want to accept connections  from outside the LAN but is unable to, whereas other computers on the same LAN are able to connect to the server.
I seem to be confused over the term "server", which sort of implies people tring to connect TO it, vs. a process on the server wanting to connect somewhere else, maybe to load files or something.
I love my Orbi.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 266 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
