- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI IN AP MODE
- Mark as New
- Bookmark
- Subscribe
- Permalink
ORBI IN AP MODE
I have the current update on my Orbi, but still cannot get AP mode to work..
Does anyone have any suggestions?
I’m using a Rogers Wi-Fi modem, but have disabled the wifi capabilities of the modem.
Thnx Dan.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI IN AP MODE
Strictly speaking, you don't have to disable Wi-Fi on your Rogers modem when using the Orbi in AP mode. If you can put some distance between the Rogers box and Orbi and then you can blanket your house with Wi-Fi. Of course, this only makes sense if the Orbi can't cover the house on its own.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI IN AP MODE
Stricly speaking, using the rogers router for wifi as it's not a part of the bridge network is a bad idea. You will have issues roaming. It will interfere with available channels. It's just a bad idea from the start.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI IN AP MODE
No devices are able to connect as well.....so I have to reset orbi to factory settings and leave it in router mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI IN AP MODE
Is the Rogers Router/Modem handling DHCP?
Did you connect an ethernet cable from the Rogers Router/Modem to the WAN connection of the Orbi Router?
If both of those are "Yes", then you should be able to look at the mgmt page of the Rogers device and see what IP address is being assigned to the Orbi Router.
Once you have that, you can use the ip address, rather than the orbilogin.com to get to the Orbi mgmt page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
