- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI RBK50 - Network is up but "Offline" - I AM LOSING MY MIND
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an RBK50 that I have been using for a year. I have made NO changes. ISP is the same, the modem it's connected to is the same - literally NOTHING has changed.
Suddenly this weekend, it's been losing connection with the modem. By that I mean my Orbi network is up and available, but shows "offline".
- I have confirmed that the modem is operating normally but connecting a laptop to it directly. There are no problems. (this is an Arris Surfboard - modem only, no router)
- I have also confirmed with comcast that they can see the modem and it is operating normally (good signal, etc)
- My Orbi has the latest firmware.
- I have tried power cycling the entire network several times
- I have even tried a full factory rest and fresh install of my Orbi
Occasionally I can get it back online briefly, but then it falls off.
The *only* possible issue I have been able to isolate is that I have recently been trying to upload several gigabytes of photos on one of my laptops to a google drive account.
Is it possible that upload is being swamped and the router is falling over? Is that a thing? Any other suggestions other than the possibility that the router is just dead? Literally NOTHING has changed and I have tried literally every suggestion I have tried on the forum (above and beyong the normal trouble shooting)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI RBK50 - Network is up but "Offline" - I AM LOSING MY MIND
You can get this information from the home page after you access orbilogin.com
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was able to get there at one point, and it showed me that "no internet access" red badge. I just went back to check the IP and answer your questions and I can't get there at all. The iphone app can't find the Orbi now either. This happened before and it did eventually come back, but I can't tell you why....
This ran for a full year with no issues. I don't understand it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the status of the LED on the back of the router and the ring on the top if the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Swapped LAN cables between the ISP modem and Orbi?
Disable IPv6 on the Orbi router and see...
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's an arris sb6141 surfboard.
I have already tried replacing the ethernet cable. I can try disabling IPv6.
I had to step away but ran a little experiment before leaving. Each time I restart the upload to Google drive, I lose the router's connection to the modem. When I eventually get it back up (full power cycle + time) and then DON'T restart the upload, it stays up!
So it looks like the upload is knocking the router off for some bizzare reason.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This sounds to me like the ISP modem gets overloaded with packets from Orbi and then gets blocked. This can be caused by bufferbloat.
I believe that reducing the MTU size might help. The MTU size configuration can be found under >> ADVANCED >> Setup >> WAN Setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
The 6141 modem is getting a bit older for it's model. Also known for some bad performances and operation over it's history.
How long have you had the modem?
What is your ISP speed UP and Down that you pay for?
Let us know if any suggestions help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya, you should be ok as far as speed for this modem.
Is IPv6 disabled on the router?
Has a power OFF of the modem and Orbi router for 30 seconds thn back on with the modem first, then Orbi router?
You might try a factory reset ON the router as set up from scratch.
I would also download the FW file for the Orbi router, re-apply it, factory reset and setup from scratch and see if the problem still happens between the router and modem.
@jlkass wrote:
I get about 60 down and 6 up, which I realize is not great. The isp is telling me they see zero problems with the modem although I understand that may not include an evaluation of its overall performance; just that it’s not “broken”
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have your prior router? IF so, you might connect it up and then set the Orbi up for AP mode and see if the problem still continues...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I do not have my old router unfortunately - but this is a really good suggestion and it should be easy enough to get my hands on one to at least test this.
I have also confirmed that IPv6 is disabled. I just went in an set MTU to 1400 and did a test. Looks like the bufferbloat is still a problem. And this is with basically nothing running right now...
<a href="http://www.dslreports.com/speedtest/44956967">
<img src="http://www.dslreports.com/speedtest/44956967.png"></a>
- Mark as New
- Bookmark
- Subscribe
- Permalink
After I updated MTU to 1400 and did that buffer test, I went hunting for the QOS settings thinking that maybe I could throttle some stuff to prevent this thing from falling over.
Turns out, the orbi runs a speed test and then automatically sets your QOS. Ok, I guess...
So I click to start the speed test and what do you know - it knocks me off.
So now I’m offline. Router shows no IP from the ISP and the LED on the orbi base is amber. An attempt to reboot from the app failed with the message “something went wrong”. So now I’m bouncing both the modem and the router.
Why would a speed test knock this thing off?!?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It shouldn't knock you off line.
There is either a problem with the modem, or the Orbi router.
I presume if your doing speed tests with a directly wired PC and not getting knocked off line this way, there maybe a problem at the Orbi.
You would need a different router or different Orbi to test this out...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
