- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
ORBI RBK50/RBS50 Tips, Tricks, Hidden Secrets, etc.,
A place to share ORBI goodies/secrets.
Replace 192.168.1.1 bellow with your Orbi Router or Satellite IP:
Please don't forget to share yours. Cheers! :-)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: ORBI RBK50/RBS50 Tips, Tricks, Hidden Secrets, etc.,
To check out Orbi backhaul signal strength, try this:
- root@RBR50:/# wlanconfig ath2 list
ADDR AID CHAN TXRATE RXRATE RSSI MINRSSI MAXRSSI...
14:59:c0:3b:e7:xx 1 157 780M 780M 27 0 33 ...
14:59:c0:3b:e1:xx 2 157 1300M 1300M 40 0 50 ...
Backhaul chan is 157. One of my Satellites (-68 dBm) is near the edge, too close to -70dBm for comfort. That also explains the reason for lower link rate of 780M.
- 27 - 95 = -68 dBm
- 40 - 95 = -55 dBm
Signal Strength | Result | Required for | |
-30 dBm | Amazing | Max achievable signal strength. The client can only be a few feet from the AP to achieve this. Not typical or desirable in the real world. | N/A |
-67 dBm | Very Good | Minimum signal strength for applications that require very reliable, timely delivery of data packets. | VoIP/VoWiFi, streaming video |
-70 dBm | Okay | Minimum signal strength for reliable packet delivery. | Email, web |
-80 dBm | Not Good | Minimum signal strength for basic connectivity. Packet delivery may be unreliable. | N/A |
-90 dBm | Unusable | Approaching or drowning in the noise floor. Any functionality is highly unlikely. | N/A |
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
If you don't want to figure out the backhaul interface or do the math, try this:
- root@RBR50:/# cat /tmp/satellite_device_info
"mac address": "xx",
"ip address": "192.168.1.9",
"module name": "RBS50",
"serial number": "xx",
"signal strength": "-55",
"current version": "V2.3.1.48",
"backhaul status": "2",
"device name": "Orbi Satellite-1"
"ip address": "192.168.1.8",
"signal strength": "-68",
"device name": "Orbi Satellite-2"
root@RBR50:/#
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
For the sake of completeness:
not to be confused with
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
If you need telnet on your MacOS:
First you’d download the latest, inetutils-1.9.4.tar.gz, inetutils package from GNU Telnet. To compile/install telnet locally on your MacOS, assuming you have already installed Apple Xcode, which is free from App Store:
- tar xvzf inetutils-1.9.4.tar.gz
- cd inetutils-1.9.4
- ./configure
- make
- sudo make install
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I've found ZOC works well for telnet on OSX:
https://www.emtec.com/zoc/index.html
RBK50 v2.7.2.102
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Another command for similar information:
root@RBR50:/# cat /var/current_satellite_list
"mac address": "xxxxxxxx",
"ip address": "192.168.1.2",
"serial number": "xxxxxxxx",
"device name": "Orbi Satellite-1",
"current version": "V2.3.1.60"
root@RBR50:/#
My Setup | Internet Fiber ONT 250↓/250↑ | ISP Telenor | Wifi Router Orbi RBK50 AC3000, Router Mode, Wired Backhaul / Orbi RBK852 AX6000, Router Mode, Wireless Backhaul | Switches Netgear GS208 | Time Zone CET (Sweden)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Read your latest Orbi DNS quiries log:
root@RBR50:/# cat /tmp/dnsmasq.log
Other DNS-related commands:
root@RBR50:~# cat /etc/hosts
root@RBR50:~# cat /tmp/hosts
root@RBR50:~# cat /etc/dnsmasq.conf
root@RBR50:~# cat /tmp/resolv.conf
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Orbi Radio, useful commands:
root@RBR50:~# cat /tmp/netscan_if_conf
eth1 wired 1
ath0 2G 0
ath01 satellite 0
ath1 5G 0
ath2 satellite 0
ath02 2G-GUEST 0
ath11 5G-GUEST 0
eth0 wired 2
root@RBR50:~# cat /tmp/wifi_topology
NORMAL:AP:wifi0:ath0:@wifi-iface[0]:wl
BACKHAUL:AP:wifi0:ath01:@wifi-iface[1]:wlg_ap_bh
NORMAL:AP:wifi1:ath1:@wifi-iface[2]:wla
GUEST:AP:wifi0:ath02:@wifi-iface[3]:wlg1
GUEST:AP:wifi1:ath11:@wifi-iface[4]:wla1
BACKHAUL:AP:wifi2:ath2:@wifi-iface[5]:wla_2nd_ap_bh
ath0 (Fronthaul 2.4GHz)
ath01 (Backhaul 2.4GHz)
ath02 (Guest 2.4GHz)
ath1 (Fronthaul 5GHz)
ath2 (Backhaul 5GHz)
ath11 (Guest 5 GHz)
root@RBR50:/# wlanconfig ath0 list active -l
Channel 1 : 2412 Mhz 11ng C CU Channel 8 : 2447 Mhz 11ng C CU CL
Channel 2 : 2417 Mhz 11ng C CU Channel 9 : 2452 Mhz 11ng C CU CL
Channel 3 : 2422 Mhz 11ng C CU Channel 10 : 2457 Mhz 11ng C CL
Channel 4 : 2427 Mhz 11ng C CU Channel 11 : 2462 Mhz 11ng C CL
Channel 5 : 2432 Mhz 11ng C CU CL Channel 12 : 2467 Mhz 11ng C CL
Channel 6 : 2437 Mhz 11ng C CU CL Channel 13 : 2472 Mhz 11ng C CL
Channel 7 : 2442 Mhz 11ng C CU CL
root@RBR50:/# wlanconfig ath01 list active
root@RBR50:/# wlanconfig ath02 list active
root@RBR50:/# wlanconfig ath1 list active -l
Channel 36 : 5180 * Mhz 11na C CU V VU V80- 42 Channel 52 : 5260 *~ Mhz 11na C CU V VU V80- 58
Channel 40 : 5200 * Mhz 11na C CL V VL V80- 42 Channel 56 : 5280 *~ Mhz 11na C CL V VL V80- 58
Channel 44 : 5220 * Mhz 11na C CU V VU V80- 42 Channel 60 : 5300 *~ Mhz 11na C CU V VU V80- 58
Channel 48 : 5240 * Mhz 11na C CL V VL V80- 42 Channel 64 : 5320 *~ Mhz 11na C CL V VL V80- 58
root@RBR50:/# wlanconfig ath2 list active
Channel 100 : 5500 *~ Mhz 11na C CU V VU V80-106 V160-114 Channel 124 : 5620 *~ Mhz 11na C CU V VU V80-122 V160-114
Channel 104 : 5520 *~ Mhz 11na C CL V VL V80-106 V160-114 Channel 128 : 5640 *~ Mhz 11na C CL V VL V80-122 V160-114
Channel 108 : 5540 *~ Mhz 11na C CU V VU V80-106 V160-114 Channel 132 : 5660 *~ Mhz 11na C CU V VU
Channel 112 : 5560 *~ Mhz 11na C CL V VL V80-106 V160-114 Channel 136 : 5680 *~ Mhz 11na C CL V VL
Channel 116 : 5580 *~ Mhz 11na C CU V VU V80-122 V160-114 Channel 140 : 5700 *~ Mhz 11na C V
Channel 120 : 5600 *~ Mhz 11na C CL V VL V80-122 V160-114
root@RBR50:/# wlanconfig ath11 list active
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The artmtd commands are useful:
Usage: artmtd -r name [<arguments> ...]
************* SN Usage:
SN read:
artmtd -r sn
SN write:
artmtd -w sn number
For instance: artmtd -w sn 1ML1747D0000B
SN should be 0~9 or A~Z
************* REGION Usage:
REGION read:
artmtd -r region
REGION wirte:
Usage: artmtd -w region region name
For instance : artmtd -w region NA
The REGION name only is "NA,WW,GR,PR,RU,BZ,IN,KO,JP,AU,CA"
************* LANGUAGE Usage:
Language read:
artmtd -r language
************* SSID Usage:
ssid read:
artmtd -r fronthaul_ssid
ssid write:
artmtd -w fronthaul_ssid SSID
ssid read:
artmtd -r backhaul_ssid
ssid write:
artmtd -w backhaul_ssid SSID
************* PASSPHRASE Usage:
passphrase read:
artmtd -r fronthaul_passphrase
passphrase write:
artmtd -w fronthaul_passphrase PASSPHRASE
passphrase read:
artmtd -r backhaul_passphrase
passphrase write:
artmtd -w backhaul_passphrase PASSPHRASE
************* WPSPIN Usage:
wpspin read:
artmtd -r wpspin
wpspin write:
artmtd -w wpspin 12345670
*************HW MODEL ID Usage:
HW MODEL ID read:
artmtd -r board_hw_id
artmtd -r board_model_id
artmtd -w board_hw_id HW_ID
artmtd -w board_model_id MODEL_ID
*************MAC Usage:ssid read:
artmtd -r mac
ssid read:
artmtd -w mac_lan 00:11:22:33:44:50
ssid read:
artmtd -w mac_wan 00:11:22:33:44:51
ssid read:
artmtd -w mac_5g 00:11:22:33:44:52
ssid read:
artmtd -w mac_2nd5g 00:11:22:33:44:53
ssid read:
artmtd -w mac_bt 00:11:22:33:44:54
*************BOARD DATA Usage:board data read:
artmtd -r board_data
board data write:
artmtd -w board_data 1102
*************BOOT PART Usage:board data read:
artmtd -r boot_part
board data write:
artmtd -w boot_part [01|02]
*************HW REVISION Usage:hw_revision read:
artmtd -r hw_revision
hw_revision write:
artmtd -w hw_revision 01
root@RBR50:/#
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
To see the events when Orbi detects radar signals you can check this in Orbi log:
> root@RBR50:~# cat /var/radardetect.log
Radar Detected at [Wed Jan 23 23:19:55 CET 2019 ] on channels [116,120,124,128]
Radar Detected at [Wed Jan 23 23:26:20 CET 2019 ] on channels [100,104,108,112]
Radar Detected at [Wed Jan 23 23:26:30 CET 2019 ] on channels [132,136]
Radar Detected at [Wed Jan 23 23:42:35 CET 2019 ] on channels [140]
Radar Detected at [Wed Jan 23 23:45:52 CET 2019 ] on channels [116,120,124,128]
Radar Detected at [Wed Jan 23 23:50:52 CET 2019 ] on channels [100,104,108,112]
Radar Detected at [Wed Jan 23 23:51:58 CET 2019 ] on channels [132,136]
Radar Detected at [Wed Jan 23 23:53:04 CET 2019 ] on channels [140]
Radar Detected at [Wed Jan 23 23:59:20 CET 2019 ] on channels [116,120,124,128]
Radar Detected at [Thu Jan 24 00:00:06 CET 2019 ] on channels [100,104,108,112]
Radar Detected at [Thu Jan 24 00:00:53 CET 2019 ] on channels [132,136]
Radar Detected at [Thu Jan 24 00:07:56 CET 2019 ] on channels [140]
Radar Detected at [Thu Jan 24 00:09:39 CET 2019 ] on channels [116,120,124,128]
Radar Detected at [Thu Jan 24 00:09:49 CET 2019 ] on channels [100,104,108,112]
Radar Detected at [Thu Jan 24 00:12:19 CET 2019 ] on channels [132,136]
Radar Detected at [Thu Jan 24 00:23:17 CET 2019 ] on channels [140]
Radar Detected at [Thu Jan 24 00:28:47 CET 2019 ] on channels [116,120,124,128]
Radar Detected at [Thu Jan 24 00:33:19 CET 2019 ] on channels [100,104,108,112]
Radar Detected at [Thu Jan 24 00:33:57 CET 2019 ] on channels [132,136]
Radar Detected at [Thu Jan 24 00:34:25 CET 2019 ] on channels [140]
Radar Detected at [Thu Jan 24 00:36:27 CET 2019 ] on channels [116,120,124,128]
Radar Detected at [Thu Jan 24 00:37:14 CET 2019 ] on channels [100,104,108,112]
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
To restore default configs and force Satellites to refresh/pull new settings from main Orbi Router,
try this:
- config default
- config commit
- reboot
- or -
Going nuclear, Factory Reset, with paper clip method.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
A practical solution that seems to resolve Satellite connection issues for users.
- @Bullyterrier wrote: I’ve found you need to do this to ‘clean out’ a satellite config.
User's testaments:
I've not tried this myself, but it's worth a shot if you're facing similar issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
If you don't want to install old-style telnet on your Mac, you can also telnet from a terminal with 'nc' command.
- nc <ip-address> <port>
Just replace the IP address with your ORBI's IP address.
- nc 192.168.1.1 23
For Windows, you can enable telnet client here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Well, if you really don't feel comfortable with telnet,
try this:
Replace 192.168.1.1 with your ORBI IP address.
Unfortunately, the text is raw, not formatted properly. However, you should be able easily find Orib/Satellite Backhaul "signal strength" value along with other goodies regarding Backhaul status.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Check FW release notes:
https://http.fw.updates1.netgear.com/<model string>/ww/stringtable.dat
<model string> = rbr## or rbs## or rbw##, etc
RBK50 v2.7.2.102
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
To get 2.4Ghz/5Ghz bands steering default value, type this cmd:
- config get enable_band_steering
To disable 2.4Ghz/5Ghz bands steering, type these cmds:
- config set enable_band_steering=0
- config commit
- reboot
To enable 2.4Ghz/5Ghz bands steering, type these cmds:
- config set enable_band_steering=1
- config commit
- reboot
If you've tried, please share your experience here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Direct web page access to RBS web page
A little mentioned method to connect to a RBS if FW is out of date or the RBS fails to sync due to FW not being in sync or on same FW version as RBR.
Users can do a factory reset on there RBS. Connect a LAN cable connected PC to the back of the RBS and wait 5 minutes approx, the PC will receive an IP and Gateway addressing on the PC. Look at the network status on the PC and you see that the Gateway should be 192.168.1.250. User can input this IP address into a web browser while the PC is connected to the RBS and access the RBSs web page. Default log in is admin and PW is password.
Old FW or Out of Sync FW on or between RBR and RBS
Recommended intermediate migration FW version is v2.0.0.74 for users who have RBR/RBS with old or first released (v1.x) versions of FW. To get from old versions of FW, prior v2.1 or v1.x, users need to first load v2.0.0.74 on both RBS and RBR. Then users can update to v2.3.x versions of FW.
RBK50 v2.7.2.102
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Would a wired connection be needed for your solution of below or can it be done via WiFi connection?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Wired is preferred however wireless should work fine. Besure to update the RBS first, then RBR as you graduate versions.
@RussFogg wrote:
Thanks for the quick response..
RBK50 v2.7.2.102
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Will give it a go in the morning, thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Let us know how it goes back on your OP:
https://community.netgear.com/t5/Orbi/Upgrading-from-V1-4-0-18/m-p/1749054#M61484
@RussFogg wrote:
Wow thanks for that tip...”Besure to update the RBS first, then RBR as you graduate versions.”
RBK50 v2.7.2.102
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You can check and change the transmission power in the different interfaces in Orbi with the following telnet commands:
1) To print the current transmission power levels:
root@RBR50:~# iwlist ath2 txpower
ath2 8 available transmit-powers :
0 dBm (1 mW)
6 dBm (3 mW)
10 dBm (10 mW)
14 dBm (25 mW)
18 dBm (63 mW)
22 dBm (158 mW)
26 dBm (398 mW)
30 dBm (1000 mW)
Current Tx-Power:30 dBm (1000 mW)
2) To change power levels:
root@RBR50:~# iwconfig ath2 txpower 3mW
root@RBR50:~# iwconfig ath2 commit
Where the interface names are as follows (for RBR50/RBS50):
ath11 (Guest 5 GHz)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have Orbi RBR50 but its rebranded and controlled by the ISP and I can't upgrade the software without ISP's concent.
Usually the ISP will release the upgrade
Many new firmware released and i still using 2.1.4.16
there is any way to re-flushing the device and install original NG firmware woithout the ISP branding
Please help
Adnan.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
If the Orbi system is operated and controlled by the ISP, then you'll need to contact the ISP for help and support as they are repsonsible for that unit under there system. Theres nothing we can do here. I recommend getting in to a retail version of Orbi then you'll have better control over it and NG will be officially supporting of it.
Please help
Adnan.
RBK50 v2.7.2.102
