Orbi WiFi 7 RBE973
Reply
ORBI RBK53 vs RBK53S
Tariq_37
Just asking about the differences between Orbi models RBK53 and RBK53S ? Is there any extra features in the second model ?
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 9
Accepted Solutions
Blanca_O
NETGEAR Moderator
Re: ORBI RBK53 vs RBK53S
Hi @Tariq_37
RBK53 and RBK53S do have the same performance and functionality. The main difference is RBK53S has a free 1-year subscription for NETGEAR Armor and no USB port.
Blanca
Community Team
Message 8 of 9
All Replies
Guru
Message 2 of 9
Tariq_37
Also noticed usb flash port in the back of RBK53 which is not there in RBK53S model !! I am confused here !!
Message 3 of 9
schumaku
Guru
AFAIK the USB 2.0 port in place on the RBR50 and the RBS50 (making the RBK53 kit) has no function - no ReadyShare, no USB storage support, no USB network sharing, .... so it was pretty save to remove.
Message 4 of 9
Guru
Possible it was removed for v2 or just wasn't included in the pictures used the spec sheets. Would have to see a physical RBRv2 to see this...
Message 5 of 9
Tariq_37
Thanks guys.. But also comparing both data sheets I noticed differences in the weight of each unit (RBK53 more heavy) and the flash memory. I am not sure about other features like Circle support as well. Also after searching, RBK53S is not available outside the US. Any other differences infos and features between both to share please !!
Message 6 of 9
Guru
Might ask NG support what all is and isn't supported.
@Blanca_O
Message 7 of 9
Blanca_O
NETGEAR Moderator
Hi @Tariq_37
Blanca
Community Team
Message 8 of 9
CrimpOn
Guru
"Free" (snicker)  How about, "Included in the product cost is a one year subscription."
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 11226 views
  • 1 kudo
  • 5 in conversation
Announcements
Orbi WiFi 7
