- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI RBR20 please help
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi recently upgraded my internet from 120 mbps to 1gb, they come and upgraded my modem and now im having issues with the orbi kicking my modem offline and no devices working
hitron CODA-4589 is my modem
and the orbi rbr20.
even with 0 sattelites running it is kicking my modem offline. unable to bridge the modem as it uses my tivo tv services i guess, but it was never bridged before i upgraded anyways.
multiple hours on the phone with no proper english help...
this is my last resort before i sell it and go get a google home or something.. i am fed up.. also getting under 100 mbps before and after upgrade, they want to send a replacement router but i dont see it the issue..
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
With my new Arris modem I have been staying online !
Just having slight issues with orbi speeds I will open a new thread and thanks for everyone who assisted and listened to me in this topic
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI RBR20 please help
Latest firmware and already did a reinstall of the router with tech support
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your ISP modem already has a built in router and wifi.
http://www.hitron-americas.com/product/coda-4589/
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-Router
I recommend you try option #2, if this doesn't work well, try option #3.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Definitely try #3 - using the Orbi in AP mode. Make sure the firmware is current, do a reset on the satellite and orbi router. As @FURRYe38 noted, if you've got dueling DHCP servers, routers connected to routers in router mode, that could cause a lot of issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware is up to date.
I stated I have tried ap mode and tried bridging it but it automatically keeps gateway option on because of my tv service.
The only part I don't understand is
"configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode."
Could you give me instructions on this please ? I'm ready to give up
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
not our groups product but let me give few pointers..
1. What is the DHCP range for the Hitron vs Orbi? Make sure they are ON DIFFERENT ranges. Orbi has feature to change it but make sure they are actually different since your have Double NAT
2. Make sure Radio is ACTUALLY OFF. Lot of ISP modems tell you it is OFF but in the background they have their hotspot running. When you have 2 radios transmitting and so close, it will cause interference.
3. I believe if you have TiVO (who uses them now a days! Get Netflix, Hulu, HBO stream or Prime Video ) ISP will force you to have CODA in NAT mode Only. Not much you can do if they force you. But if you see a Bridge or NAT-Off option, try using TiVO in Bridge mode along with Orbi.
4. Increase distance between Orbi and Hitron CODA (instead of 1 ft, make it 3-5 ft with longer ethernet Cable)
5.
- Mark as New
- Bookmark
- Subscribe
- Permalink
do post multiple screenshots of Orbi and Hitron CODA settings in imgur.com and provide links here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
1.
DHCP .. is this just up address of each modem and orbi? If so all ips on modem access page and orbilogin seem different or off by a number .
2.
Radio as in 2.4 and 5g on my modem off? If so yes..the lights are also off
3.
I use tivo and Netflix all of it I have kids 😝. Bridge mode unable because of the TiVo service.. I didn't bridge before upgrading modem..new modem from upgrading to 1g now I have issues
4.
Great distance orbi was hardwired to modem upstairs modem downstairs
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you try the RBR in AP mode with the ISP modem in router mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Ensure Beamforming and WMM is enabled. Under
Advanced Tab/Advanced Settings/Wireless Settings. Try MIMO enabled first if you any MIMO supporting devices. If not, you can disable this.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes you can use the pin in back, 15 seconds press then let go.
Yes you can still use same custom SSID name and PW.
After resetting the RBS and RBR. You might try not adding the RBS just yet, I would setup the RBR first alone and check out the access for a while. Then maybe add just one RBS.
Ensure the distance between the RBS and RBS is 30 feet to start with...
- Mark as New
- Bookmark
- Subscribe
- Permalink
My ISP modem is going offline right after, was also having connectivity wifi issues during setup. Set up one satellite and it was.blue on top.. in orbi app was showing red poor connection though
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router front of house corner where cable comes in.
Satellite 1 bedroom upstairs opposite side of house .
Sat 2 goes in garage which would connect.to satellite 1.
Speed test beside router is 450 over wifi... Should it be higher with 1g internet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Edit: now I'm offline..wifi shows full bars but my modem and router both drop connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So if you connect your PC at the ISP modem are you getting consistent speeds here?
Wired PC speeds at the RBR in AP modem are not consistent?
Wondering if your Orbi system could be faulty here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The PC or the RBR in AP mode?
Swap LAN cable between the RBR and ISP Modem?
Try this: Disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the PC dropping connect with the modem or is the RBR dropping the connection with the modem?
