Orbi WiFi 7 RBE973
Reply
ORBI RBR40 Block DNS Bypass
kproth
Tutor
Would like to block direct access to external DNS servers -- requiring all users on my home network to flow DNS through the Orbi router.  Found the Advanced option to block Services, and tried blocking access to "DNS" for all hosts except the router itself (i.e. starting at ".2" and ending at ".254").  But that also prevents access to the router's own DNS service.  That doesn't seem right, as the Block Service help screen says it blocks access out to the internet only.  Also found this page (https://community.netgear.com/t5/Orbi/Preventing-circumvention-of-OpenDNS/m-p/1300593) where someone described the same thing I tried as if it works.  If it worked for them, then what did I do wrong?  Can anyone suggest something I might have done wrong?  Or, can I not use this feature to do what I'm trying to do?
Model: RBK40| Orbi AC2200 WiFi System
Message 1 of 11
Guru
Re: ORBI RBR40 Block DNS Bypass
I would contact @OrbiPhilip via PM and have help help you...If what he mentioned in that linked post doesn't work for you...
Message 2 of 11
OrbiPhilip
Luminary
I am not running it now (v2.1.4.16), but I was at the time.  I set my block range equal to my DHCP scope, which was x.x.x.100-200.
Message 3 of 11
OrbiPhilip
Luminary
I am not running it now (v2.1.4.16), but I was at the time.  I set my block range equal to my DHCP scope.
P.S. This message editor is awful
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 4 of 11
kproth
Tutor
I tried again. Used a narrower block range, encompassing just my DHCP scope. Still no bueno -- it blocks *all* DNS access, including requests sent to the router's IP address. I only want to block requests being sent out to the internet. But since there's nowhere to specify which *DESTINATION* IP range I want to block (or which destination IP's I don't want to block) this doesn't appear to be an option. @Netgear: please make the service blocking smart enough not to block services that the router is providing...
Message 5 of 11
thorax
Has anyone found a way around this yet?  Blocking Services prevents devices from even communicating with the router over port 53.
Message 6 of 11
Guru
Have you tried the methods mentioned in this thread?
Might ask @OrbiPhilip for more help.
Message 7 of 11
thorax
Sorry, I assumed that would be clear.  Yes, I have.  It blocks *all* DNS requests, just as was stated up thread.
Message 8 of 11
Guru
DNS is assigned to port 53. So any configuration to block DNS will be bloced on port 53.
Message 9 of 11
thorax
That's not what the help page says.  It says it blocks *internet* access.  So therefore I should still be able to communicate on port 53 on the LAN, but I cannot.
Message 10 of 11
Guru
You might send @OrbiPhilip a PM to see if he can comment on this..
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 3352 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
