Orbi WiFi 7 RBE973
Reply
ORBI RBR40 with R8000
mcgunner
I have been running an R8000 router and love it. Was having trouble with getting signal from far side of house and yard. Purchased a ORBI RBR40 with satellite. When first set up as a stand alone, the ORBI worked fine. However, now I want to run a network for personal and one for private activities. I have tried running the ethernet line from modem to my R8000 internet plugin and then running ethernet cable from R8000 #4 plugout (also have ethernet cable from R8000 #3 to older computer) to ORBI RBR40 internet plugin (also have ethernet cable from RBR40 #2 to newer computer). Should mention satellite is not setting up per instructions.
So end result is that I want newer computer to use RBR40 to handle private activities like home security system, with the capability to use shared peripherals on the R8000 network and the same with the R8000 handling personal activities like bill paying, etc...
If anyone can figure this out, please help me.
Message 1 of 2
Guru
Re: ORBI RBR40 with R8000
Orbi and R8000 have same IP address so you'd need to set the Orbi IP address to 192.168.40.1 or use the Orbi in AP mode connected to the R8000 as an upgraded wifi system. Disabling ALL wifi on the R8000.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 835 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
