- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI RBR50 Dropping Connection - Firmware 2.2.1.210
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI RBR50 Dropping Connection - Firmware 2.2.1.210
What FW is currently loaded?
Does the ISP notice any issues at the modem?
Are the drops both wired and wirelsss connected devices?
What devices do you have connected to the Orbi system?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
FW 2.2.1.210
ISP Modem - ZHONE - model # znid-gpon-2402-na
The ISP noticed no issues with the modem but the were able to see the drops from the router.
We rarely use it wired so all issues have been noticed wirelessly.
Connected devices include - iPhones, iPads, Kindles, printer, TV, Roomba, Alexa
Channel being used was Auto - I have changed this to 6 as suggested to see if we see a difference
Yes for WiFi neighbors - there are 8 houses on our street and all would be WiFi
I have disabled the suggested settings and will see if that makes a difference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try to test wired connetions as well next time.
What channesl are your neigbors using?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I too have noticed the Orbi drops the internet (both wifi and wired) at least once a day since the 2.2.1.210 update. I have confirmed it is not the ISP modem. The only trick i have found to get it to reconnect, besides waiting 10+mins, is to go into the router and hit the test button under the Internet setup. Not sure if it actually helping but it seems to get the Orbi to reengage the modem.
The weird thing is that under Internet Status it is GOOD, even when the rest of the house doesnt have internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
How was the FW updated? Via autoupdate? Has the system been powered OFF along with the modem for 1 minute then back on?
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is the only change I made to get it working, and I have MIMO, Beamforming, and fast roaming enabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Others have reported the Circle seems to cause problems.
Have you tired manually loading v210 FW on the router and factory reset and setup the router from scratch, then enable circle and see if the problem still happens?
@Deavert wrote:
I had the same issue since installing 2.2.1.210. I found the fix for me was to disable Circle, even though it is one of the primary reasons I chose the Orbi. I have not had a drop since disabling it and it’s been over a month now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a RBR50 and 2 RBS50 satellites. All are on firmware V2.2.1.210.
The system was constantly dropping connections throughout the day. I was also randomly receiving SSL/certificate warnings when visiting websites from my PC and Android phone.
Yesterday, I logged onto my RBR50's web interface, went to Advanced > Advanced Setup > Wireless Settings > Changed my 2.4 ghz power settings from 100% to 75% AND enabled Fast Roaming.
I have not experienced a dropped connection nor received a SSL/certificate warning since making both changes at the same time. For what it's worth, I did not do a factory reset on the router or satellites before making the changes, and my channel settings are still set to the default settings. I hope this helps someone else experiencing similar issues. If I experience dropped connections again, I will re-post.
