Orbi WiFi 7 RBE973
Reply
ORBI RBR50 crashing
valentinul
ORBI RBR50 crashing
Hello everyone,
I've bought an ORBI RBR50 a couple of months ago and for some reason after the latest update (V2.5.1.8) the router crashes every second day or so....
I've did an reset on the satellite as I was reading this forum and this was a suggestion....now I'm thinking of downgrading to the previous version -> 2.3.5.30
Anyone else having this kind of issues ? If yes, any fix available ? Ideas?
Thank you!
br
valentin
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Retired_Member
Not applicable
Re: ORBI RBR50 crashing
@valentinul wrote:
Hello everyone,
Thank you!
br
valentin
It's true 2.5.1.8 is a mess
revert back now and stop performing manual updates
Message 2 of 4
Guru
Did you reset the router as well? If not, try this on the RBR...
You can try Voxels FW for Orbi:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883...
You can revert back to stock FW if it doesn't work out for you.
@valentinul wrote:
Hello everyone,
Thank you!
br
valentin
Message 3 of 4
Retired_Member
Not applicable
no need.    Revert in process
@valentinul wrote:
Hello everyone,
Thank you!
br
valentin
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 693 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
