- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI RBR50 is going in and out of WIFI
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been having issues with my ORBI RBR50 (1) Router and (1) Satalite. The wifi keeps cutting in and out while still connected and running very slow.
I have a 2,000 square foot house two stories. The Router and modem (spectrum) are located down stairs next to each other.
Anyone have any suggestions on how to fix the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI RBR50 is going in and out of WIFI
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch in the configuration?
