- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI RBR50 w/ 2 RBS50 Satellite issues:
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an Orbi RBR50 daisy-chained with 2 RBS50 satellites. Neither satellite is connected by ethernet cable. Only wifi. Connections from the Router to Satellites are 5G and GOOD. Is it normal that wireless speeds next to my router are 200MBPS and at my satellites I'm only getting 75-100MBPS? Thanks,
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Also having wifi signal broadcast from modem can cause interference issues as well.
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Please disable ALL wifi radios on the upstream router...Give one of the above suggestions a try.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI RBR50 w/ 2 RBS50 Satellite issues:
Both satellites are the same, or is the "far one" lower than the "near one"?
How is speed being measured?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Satellites are setup in A-B-C Daisy-Chain.
A ---> B---> C
A Orbi router (ground floor office, hardwired, acting in router mode)
B satellite (ground floor kitchen)
C satellite (2nd floor play room)
Speedtest.net app for speed tests via iphone 11 or ipad.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the Mfr and model# of the ethernet switch in the configuration?
Armor, Circle, Daisy Chain needs disabling for ethernet connected RBSs, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Be sure your connected to the RBS and not the RBR. You need to disable the wifi radio on your device, then go near the RBS, 4-6 feet. Then enable the wifi radio on the device. This will ensure it's connected to the RBS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will report back later this evening when I get home. Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
2.5.1.8
Modem:
Spectrum brand?
E31T2V1
Router:
Askey Wave 2
RAK2V1K
3400
30-40 feet
1/48
0
Already enabled.
Fast roaming disabled causes connection isssues. Otherwise I disabled IPv6. The rest were already off.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am getting 234mbps at the router. 110-ish at the satellites. Basically half at the satellites with 5G connections and good backhaul status.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@steve04KU wrote:What Firmware is currently loaded?
2.5.1.8
Modem:Spectrum brand?
E31T2V1
Router:
Askey Wave 2
RAK2V1K
Is the RBR working in AP mode or router mode? I see you have a router already in front of the RBR...
What is the Mfr and model# of the ethernet switch in the configuration?Any network switches in between the RBR and RBS or is the RBSs directly connected to the RBR?
What kind of LAN cable are you using to connect the RBS to the RBR? CAT6?
3400
30-40 feet
1/48
0
Already enabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBS are connected to RBR by 5G signal. No hardwire. I suspect this may be the issue and could be considered normal? That’s what I need answered. Why are my SAT speeds 1/2 than the speed at the router (wirelessly).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem Combo Units:
Couple of options,
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m getting 220 at the router. 190 at SAT1 30’ away and am getting 150 at SAT2 40’ away from SAT1. Daisy chain mode.
I can live with this.
Many thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working better. Enjoy.
