Orbi WiFi 7 RBE973
Reply
ORBI RBR50 will not recognize internet source cable from modem
HighTide
Follower
Orbi was working great (have two satellites inside and just bought the outdoor sat for the poolhouse).  We had a bad lightning strike near our home last night.  I have gone through all sorts of resets, etc. and during the setup it will not recognize the internet cable from the cable modem.  Error says "Check the Ethernet Cable" but I have confirmed the cables are good and I have excellent speed from the modem.  The modem is a simple / no wifi modem with just one port and that is not the issue.
It is impossible to contact Netgear support plus they want $$$$.
I am a Best Buy Geek Squad premium member and unfortunately know more than the two techs I spoke with today.
Questions:
Do you think I can get the router repaired?  I will pay.
If not, can I buy just a router (no bundle).
How can I speak to a live person at Netgear?
Thanks very much!!
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 2
Guru
Re: ORBI RBR50 will not recognize internet source cable from modem
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
Has a factory reset been performed on Orbi system and set up from scratch?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1496 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
