Reply
ORBI Satellite cannot connect
Seattlites
No matter what I do and where I place the satellite, even in areas where I have a strong WiFi signal from the base unit, it will not connect and always provides the magenta light.  The base unit has the latest firmware, however, the satellite because it has never connected, does not.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 6
TomMac
Guru
Re: ORBI Satellite cannot connect
Have you factory reset the Sat ?
Morse is faster than texting!
Message 2 of 6
5597jade
Connected to moden by still not working
do you have a phone number can call and talk ?
Message 3 of 6
5597jade
all moden connected bu still not owrking
Message 4 of 6
Seattlites
Thanks.  Reset worked and I was then able to update firmware separately.
Message 5 of 6
TomMac
Guru
good to hear... if you update the software later, it was recommended to me to update the Sat first and then the Main..
Do this by the manual updating option ( download sw to computer first ) and not the automatic method
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3262 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
