Orbi WiFi 7 RBE973
Reply
ORBI Satellite not transmitting 2.4ghz
Chris1984
Tutor
My Orbi satelite is not transmitting a 2.4ghz chanel and the closest devices are not connecting directly to it .
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 7
Guru
Re: ORBI Satellite not transmitting 2.4ghz
Does it connect and synce to the Orib base?
Has a factory reset been performend then re-added to the base?
If so and the satellite isn't working, you'll need to contact NG Support and ask for an RMA.
Message 2 of 7
ekhalil
Master
How do you know that it's not transmitting on the 2.4 GHz band? Have you made a wifi scan and confirmed this?
The fact that your closer devices to the Satellite are not attaching to it does not mean that it's not transmitting the radio.
Message 3 of 7
Chuck_M
Mentor
Log onto the satellite web gui  (not the router) and tell us what the status screen says as far as the status of the satellite
Here is an example from mine
Message 4 of 7
Guru
Any status on this?
Message 5 of 7
Budgeuk
Mine shows 2.4 grayed out
Message 6 of 7
Guru
Can you confirm that it's not transmitting with mobile app on a Android if you have one. Wifi Analyzer. This will show you if the radio is broadcasting or not.
If it's not, I recommend you get ahold of NG support and ask about an RMA>
https://www.netgear.com/mynetgear/registration/login.aspx
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 5576 views
  • 2 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
