drmed's avatar
drmed
ORBI VPN on Windows 10 not working
I have set up my orbi for VPN, created a DDNS entry, downloaded the setup files.
I have no issues connecting to the VPN on my Android PIE device using the smart_phone.opvn, also no issues from a Mac using tunnelblick (openvpn alternative for Mac OS) using the nonwindows files donwloaded from the ORBI setup page. However when I try my windows 10 machine using the windows.zip from the setup page (after unzipping it into the configuration folder of OPENVPN), I cannot get any connection. I did rename the TAP adapter to NETGEAR-VPN as suggested.
The intersting thing is, if I use the smart_phone.opvn file instead on the windows specific setup files on my window machine, I can connect to the VPN without any issues.
What is the issue? The main difference in the OPVN files (smartphone vs windows client) is TUN vs TAP.
Any suggestions?
  • This is the screenshot from my ORBI VPN setup page
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi drmed
    Welcome to NETGEAR Community!
    - What is the error message when you connect on your Windows 10 computer?
    - What version is the OpenVPN client used?
    Kindly set Tap Mode Service Type to TCP and try to connect again.
    Blanca
    Community Team
    • Blanca_O's avatar
      Blanca_O
      Hi drmed
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
      Blanca
      Community Team
