- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI Wifi speeds slow
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an ORBI RBR 50 and used to get 300 dl speeds over the air and the speed matched if i did it thru the app. Recently the speed thru the app is still the same 200-300 dl but if i check the speed over the wifi it drops to 12-20. Ive rebooted the system a number of times and the speed is still very slow. Sometimes in single digits. Help!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to do a backup configuration to file for safe keeping. This saves time if a reset is needed later on again. Please mark your thread as solved so others will know.
Enjoy.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI Wifi speeds slow
Are all devices having the same slow speed or just 1?
Has anything changed since this has started?
If nothing has changed, it could be channel interference, or the device that is having the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Aloha
unFortunately all devices show that speed. I checked with my MacBook. iPhone and all of our iPads. So maybe 8 devices It used to work great. Not sure what changed. I haven't changed any settings.
thanks
lyle
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the exact same issue. It just started last week. I had no issues prior. Were you able to resolve it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
@Lylemats wrote:I have an ORBI RBR 50 and used to get 300 dl speeds over the air and the speed matched if i did it thru the app. Recently the speed thru the app is still the same 200-300 dl but if i check the speed over the wifi it drops to 12-20. Ive rebooted the system a number of times and the speed is still very slow. Sometimes in single digits. Help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ChloeJ wrote:I have the exact same issue. It just started last week. I had no issues prior. Were you able to resolve it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Aloha
i did a factory reset and speed came back. Don't know why I didn't think of that earlier
thanks
lyle
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had already ensure mosted current firmware and reset the main and satellite and went through the setup again - that did not help. I had noticed my satellite connection was at 2.4GHZ, tried changing the channel for 5GHZ and that seemed to help - my issue was only devices connected to the satellite. So far so good.
- Mark as New
- Bookmark
- Subscribe
- Permalink
