- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI disconnects temporarily when i go upstairs
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the Orbi, 2 satellites. My connection temporarily disconnects when I go upstairs. For mesh routers, I should have a continuous connection correct? I have noticed my connection go out when I am wifi calling or video calling. Any solution here? If i separate the 2.4 and 5 ghz, would this also cause this issue?
Enabled: beamforming, mu-mimo
Disabled: Fast Roaming, Daisy chain - I noticed frequent disconnects when I had these enabled. Is this why it's not constant?
3500 sq feet home, 3 stories, but mainly use the first 2.
thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI disconnects temporarily when i go upstairs
It's up to wifi devices to pick and choose which signal source they connected too. If the signal gets bad enough, even if your on a call, the device may switch on it's own which would cause this temporary disconnect.
Fast Roaming should help some though it's still up to the device.
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings. Beamforming should be enabled most of the time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jacoblee16 wrote:Disabled: Fast Roaming, Daisy chain - I noticed frequent disconnects when I had these enabled. Is this why it's not constant?
Daisy Chain should have no effect on this. If you notice that both satellites connect directly to the router, then disabling Daisy Chain makes sense.
Fast Roaming is intended for this situation, where a device moves from one Orbi device to another. I have it set "on".
