- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI does not deliver
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI does not deliver
Hope you can return it and get your money back. Mine has been working great for four years.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ctbhongkong wrote:
Basically, I have an apartment of 2,300 sf with one RBR 50 and 2 RBS 50. Multiple start overs, syncs, powers on and off and the network works for awhile then doesn’t. I don’t see many posts from 2020 so I assume this product hasn’t done well. Pretty disappointed in spending so much money on a shoddy product that has very little reach. My previous ASUS router on its own was better than this mess.
I have the same exact system in a 3200+ sq ft home. It works flawlessly. So I'm going to go with user error.
Tell me how you have it setup?
Who is your ISP?
What device is your Orbi router connected to?
Are your satellites wired or wireless?
If wired, what cable size was used, as size determines speed.
Cat 5 10/100 Mbps 100 MHz
Cat 5e 1000 Mbps / 1 Gbps 100 MHz
Cat 6 1000 Mbps / 1 Gbps >250 MHz
Did you reboot your ISP modem/router, before starting the Orbi router install?
Have you changed the network cable connected from the ISP device to your Orbi router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been enjoying my 1 RBR50 and 1 RBS50 in a 5000sq ft home for past couple of years. No big problems here.
For your size of home, Having too many RBS maybe a cause of problems as well. Try with just 1 RBS. The 50 series Orbi is quite powerful and range is pretty good and far. Having too many wifi signals can cause problems is a smaller home size will be problematic.
If you want more help on this then it would be good for more information. Orbi systems DO work very well. However sometimes there needs to be some troubleshooting to find out what the real problem is.
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
