Reply
Highlighted
Follower
ORBI general question before buying
I have one area in the house that is a dead zone.
I don't want to change out my router because it is a good router.
TP -Link 7200 router.
Can you mix and match hardware? Can I connect an ORBI wall plug satellite and have it work with my TP-Link 7200?
Message 1 of 3
Highlighted
Sensei
Re: ORBI general question before buying
No.  ORBI is a "system".  Routers and Satellites communicate with each other, and NOT with anything else.  You can connect an ORBI router to your existing router in AP (Access Point) mode, and have it connect to a remote Satellite.   In that case, most people would turn off the WiFi function on their existing router and enjoy the benefits of seamless transition between the ORBI router and satellite using a single WiFi.
There are other ways to extend an existing WiFi sytem, but not the way you are proposeing.
I love my Orbi.
Message 2 of 3
Highlighted
Guru
 30 feet is recommended in between base router and satellite to begin with depending upon building materials.
5000sq ft I use one base router and one satellite 40 feet in between.
The Orbi wifi is designed to be the only wifi source with in the home. Having other wifi can and will cause interference problems. You can turn OFF other wifi on routers and use the Orbi in AP mode if you wish to use a different router as your main host router.
My Setup (Cable 900Mbps/50Mbps)>CAX80>XR450 v2.3.2.106(Router Mode)>RBK853 v3.2.11.2(AP Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 394 views
  • 1 kudo
  • 3 in conversation
Announcements
