Reply
ORBI on 1.8.0.6 only shows the .18 release
bobfa
Follower
OK I want to update the firmware on my AC3000 ORBI . The auto update shows the .18 release for the RBR but will not find anything for the RBS.
I am going to manually download the firmware and update it.
OK and I did backup the config file so I can restore it.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
DarrenM
NETGEAR Moderator
Re: ORBI on 1.8.0.6 only shows the .18 release
Yes I suggest to do the manual update.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 262 views
  • 0 kudos
  • 2 in conversation
Announcements
