Kriffin
Sep 15, 2019Aspirant
ORBI (router master) + satellite with ethernet in enter ?
Hello community,
I did not find the answer to my question on the marketing page of the site ... Is it possible to have satellites connected to the ORBI master via the Ethernet port? I do not want to redistribute a WiFi network. But redeploy the full power of Ethernet via the WiFi.
Thanks in advance.
> I host a server behind my router and have port 22 forwarded so that I
> can SSH to the server. [...]
You need to forward _some_ external port to port 22 on your server.
Using some external port other than 22 for that might amaze you by the
drop in the number of unwanted connection attempts you'll see.
> Is this normal for networks that have port 22 open for SSH?
That's been my experience.
> Is it likely someone is targeting my network or machine?
It's likely that many ones are trying every network on the Internet.
> Could this open port have been discovered via a port scan?
Sure, but many/most such attacks simply try port 22.
> Is it likely this is the reason I couldn't connect to my server?
I know nothing about that problem.
Years ago, I tried using external port 22. Big mistake. Complaining
to ISPs of offenders could easily be a full-time (unpaid) occupation.
Moved to external port 22 + N * 100, and get a few attempts per year.
"-p <port_number>" is your friend.
