Reply
ORBI wi fi 2.4 ghz / 5ghz
JCR1
Follower
Hello, My security cams and smart plugs only work on 2.4 ghz. My orbi wi fi says on my smart phone transmitting on  5ghz.. How can I get to transmit on 2.4 to pick up my cams and smart plugs thx
Model: RBK44| Orbi AC2200 WiFi System
Message 1 of 2
aaz
Virtuoso
Virtuoso
Re: ORBI wi fi 2.4 ghz / 5ghz
The Orbi transmits on both 5Ghz and 2.4Ghz.  Your security cams will use the 2.4 band and your phone will use the 5ghz band - there is no problem with my phone connecting to devices on the lower band through the Orbi.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1304 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
