- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI
> How do I connect my securety cameras with port forwarding?
With my weak psychic powers, I have little to no idea what your
router is, or what your (unspecified) "my securety cameras" might be.
You also seem to have missed the ORBI forums:
https://community.netgear.com/t5/x/ct-p/home-orbi
But, even there, a better description of your gizmos (actual maker and
model number, firmware version, and so on) couldn't hurt.
A simple Web search for keywords like, say:
camera port forwarding
might find a page or two, too. Most routers handle this stuff in very
similar ways, so it should be possible to translate almost any example
to your (unspecified) ORBI router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI
You don't say which model of the Orbi you own, but you might get better answers if you put your questions in the appropriate section of this user-to-user self-support forum:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI
Port Forwarding is not needed with cameras. Just enable uPnP and connect your cameras using there setup wizards or software. I have 3 wireless cameras that are connected to the routers main wireless SSID name and Password. I don't use WPS.
@BillG9wrote:How do I connect my securety cameras with port forwarding?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI
If you port forward the camera(s) they will be exposed on the internet and can be attacked (cameras aren't exactly know to be secure or updated). I would use the VPN capability built into the Orbi and use a VPN client to tunnel through to your internal network so you can see all cameras on your network with one configuration. Of course you need a VPN client on your device like OpenVPN with the configuration installed from the router VPN. Also may need DDNS configured to keep OpenVPN embedded in the router aware of your public IP.
If you want to port forward each camera, you will need a port forwarding configuration for each camera by finding out which port(s)/protocols(s) they communicate on and configuring those in the router Advanced->Advanced Setup->Port Forwarding and pointing to the internal IP address of the camera. But then you also need a public static IP ($) or some sort of domain name ($) to DDNS working on the camea or router so that when you try to connect to the camera via your domain name ($) it can send the traffic back to the right (public) IP. I suggest using the router DDNS and VPN instead in the Advanced Setup - more secure, built in and less hassle.
