- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI
- Mark as New
- Bookmark
- Subscribe
- Permalink
ORBI
Trying to figure out if my orbi is running a 2.4 or 5 ghz to install a la crosse weather station. It only uses the 2.4 ghz and won't install.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI
Orbi has both 2.4 and 5 GHz bands.
Please have a look at the following posts for related discussion and suggested solution (by temporarily disabling the Orbi 5GHz band):
https://community.netgear.com/t5/Orbi/Orbi-and-La-Crosse-weather-station/m-p/1468825
https://community.netgear.com/t5/Orbi/HOW-TO-DISABLE-5G-TEMPORARILY-ON-ORBI-ROUTER/m-p/1469365
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI
What does, "won't install" mean?
When trying to connect something to a wifi network, it isn't usually necessary to disable 5 GHz. If the weather station cannot see 5 GHz, it won't try to connect to it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI
This is an issue with this weather sensor that can’t select 2.4GHz if shared with 5GHz in same SSID, that’s why the proposed workaround.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI
I would suggest turning down the power on the 5Ghz radio first before disabling the 5Ghz radio.
