- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI50 networking
- Mark as New
- Bookmark
- Subscribe
- Permalink
Many thanks
Mark
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can use a wired backhaul between your RBR50 router and RBS50 satellite. Plug the cable into one of the LAN ports of the router and the first LAN port on the satellite and reboot the satellite. The web UI will show it using a wired backhaul for the satellite in the Attached Devices menu instead of the 5GHz WiFi backhaul.
If possible, do not use a switch between the router and satellite. If you do use a network switch, do not use a green switch (one that saves power by disabling/throttling ports).
See https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy... for NG's KB article on doing this.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI50 networking
Many thanks for the quick reply and that’s perfect
Many thanks
Mark
