Orbi WiFi 7 RBE973
Reply
ORBS 50 and ORB103 Satellite
ademiluyi
Can I use satellites that come with ORB103 to extend my ORB 50 Router?
Message 1 of 6
Guru
Re: ORBS 50 and ORB103 Satellite
ORB103?
Is this a NG product? Or other Mfr?
Message 2 of 6
CrimpOn
Guru
When they are menufactured, Orbi's are given a WiFi name that begins with "ORBI".  For the specific model number, please look on the product label, usually on the back or bottom of the unit.  (VERY small letters.)
As far as I know, every Orbi satellite will function with the Orbi RBR50 router.
Message 3 of 6
ademiluyi
Both are ORBI products:
Orbi R50 and the satellites are from ORB103
Message 4 of 6
CrimpOn
Guru
If they all came in the same box, then they were probably set at the factory to work together.  Otherwise, satellites from one system can be moved to another Orbi router by "resyncing" them.  (check the internet for videos on how to do this.)  The router from a one system cannot be used as a satellite on another router.  It can be "attached as an access point", but cannot be used to expand the original "seamless" Orbi.
Message 5 of 6
Guru
Is there a support page link to this ORB103? Not seeing this in NGs support page list.
Most NG satellites are RBS or RBWs or an RBSY model nomenclature...
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 877 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
