Orbi WiFi 7 RBE973
Reply
Obi mesh connection
Pylona
Obi mesh connection
I want to know how the Orbi communicates between the main box and the satellites.  is the mesh a separate ring with some sort of proprietary protocol - ie it does not use the main BW that the users will acess for connectivity?
Message 1 of 2
Re: Obi mesh connection
hi
at the present time the sats communicate back to the router only so the way its works is in a star type topology
the sat and router communicate with a dedicated 5 gig 1733M wifi connection
so think of the dedicated 5 gig backhaul a bit like an ethernet connection between the two
both orbi router and sat transmit both a 2.4 gig 400M and a 5 gig 867M connection for the clients using a single ssid for all transmissions
mesh type topology is not currently supported but is suggested it may in future firmware , however testing of other mesh systems suggest greater losses than the current star topology of the orbi system so if it does change i hope they make it a choice of star or mesh
pete
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2724 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
