Orbi WiFi 7 RBE973
Reply
One of 2 Orbi satellites shows offline
Lizardfish
Follower
Newly bought Orbi system, less than a week, setup and working was no problem, suddenly a satellite shows offline yesterday, rounder and another satellite was ok.
All clients connected to the offline one, has no internet access, and will not switch. Power off/on this satellite alone fix the problem.
Firware are the latest, am worrying the stability of the Orbi system. I were using R8000 router, never requires a single reboot for months... What to look at? Still within returning window... thanks a lot!
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
CrimpOn
Guru
Re: One of 2 Orbi satellites shows offline
Netgear provides 90 days of "complimentary support" with new Orbi purchases.  When you register the product, there is a link on the registration web page to contact support.  If you decide to call them, please come back and report how it went.
Message 2 of 3
Guru
What Firmware is loaded on the RBS? Should be the same and whats loaded on the RBR.
Is the Orbi system operating in Router or AP mode?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 11691 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
