- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Only the RBK43 Model powers up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi.
I purchased a Netgear product as a renewed product from Amazon.
I used about 6 months.
I reboot my router from time to time.
I logged in to the website (192.168.1.1).
The router has rebooted and there is no internet connection.
(ssid also not found)
Pressing the Reset key does not work.
If there is a way to force the router back to normal, please help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Only the RBK43 Model powers up.
Please post about this over in the main Orbi forum for your model Orbi:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@MinjeOh wrote:Pressing the Reset key does not work.
If sticking the end of a paperclip into that tiny "Reset" hold next to the power plug and holding it in until the power LED turns amber and then begins to blink does not work, this is bad. I sometimes have to hold it in for 15-20 seconds. And, one forum member recommended turning off the power, while still holding the paperclip in, then turning the power back on, while still holding the paperclip.
Does the power LED at lead glow GREEN?
