Reply
Highlighted
OpenVPN static IP - static MAC
Hi
I’ve set up the OpenVPN server on my Orbi, and devices seem to connect ok, the challenge is they seem to get a new random MAC address each time, which means I can’t assign them a static IP and they keep getting added as new devices in Circle.
Any idea how I either get static IP or MAC for the OpenVPN clients?
Thanks
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 6
Highlighted
Guru
Re: OpenVPN static IP - static MAC
@Christian_R
@Blanca_O
My Setup (Cable 900Mbps/50Mbps)>CAX80>XR450 v2.3.2.106(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 6
Highlighted
NETGEAR Moderator
Hi IcewraithUK,
Welcome to NETGEAR Community!
It is strange that device randomly change its MAC address. Does it happen to a specific device or all devices connected to the network? Do you still see the issue if OpenVPN is disabled? How do you check the MAC address?
Blanca
Community Team
Message 3 of 6
Highlighted
Hi
It only happens to devices connecting via OpenVPN, anything on the network behaves as normal but any client (win/Mac/smart) connecting using the OpenVPN gets a random MAC address. This didn’t happen with my previous OpenVPN server on pfSense, so I can only imagine it’s something to do with the implementation on Orbi?
It’s driving my Circle setup nuts though, as each time I vpn in it thinks it’s a new device...
Message 4 of 6
Highlighted
NETGEAR Moderator
Hi IcewraithUK,
How do you check the MAC address? What is the firmware version of the router?
Blanca
Community Team
Message 5 of 6
Highlighted
NETGEAR Moderator
Hi IcewraithUK,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1054 views
  • 0 kudos
  • 3 in conversation
Announcements
