Reply
Highlighted
Follower
Optimal connectivity
Dear reader,
I bougth the ORBI RBR 50 system with Two satellites.
Router is at base Floor, first satelitte is at first Floor (wired), second satelitte at the second Floor (wireless).
I have the impression that a device like laptop is automatically connected to the router/ satelitte that makes the best connection.
I have Two questions:
1. Can I manually select the Access point to connect to? If so, how?
2. In case an Access point fails connection, does the system automatically reconnect to another Access point which is available at that moment?
big Thanks in advance,
erwin van gulik
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Accepted Solutions
Highlighted
Master
Re: Optimal connectivity
@ErwinvanGulik wrote:
Dear reader,
No, the Orbi that has the strongest signal to the device, is the one the device will connect to.
If one satellite fails, and the other satellite is close enough for a connection, the device will connect to that satellite.
Orbi RBK53 System/RBR50/RBS50/RBS50. + Orbi Voice RBS40V
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
There's always a logical answer, if you have all the facts!
Message 2 of 3
All Replies
Highlighted
Master
Dear reader,
Message 2 of 3
Highlighted
If you can explain why you want to do this, perhaps someone can offer a suggestion.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 193 views
  • 0 kudos
  • 3 in conversation
Announcements
