- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Option to ENABLE SSID Gone?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've got an RBR20 router and disabled SSID broadcast a while back. I've been having issues with IoT devices staying connected and would like to re-enable SSID broadcast as a troubleshooting measure. However, all SSID options for the wireless network are gone both under Basic and Advanced Wireless, yet the ability to enable or disable SSID broadcast remains under the Guest Network options. The SSID broadcast options were gone in firmware V2.3.5.26 that I was running until today, and having just updated the firmware, I see that they're still gone in the current firmware V2.3.5.30. Have they moved the SSID broadcast settings or just removed them? If the latter, does NG expect people with hidden SSIDs to start from scratch and reset their networks to factory default in order to start broadcasting the SSID again?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
On my Orbi RBR50, running the latest firmware 2.5.1.8, SSID broadcast control remains available, on the
Advanced Tab-->Advanced Setup-->Wireless.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Option to ENABLE SSID Gone?
Thanks! I think that maybe I checked that area before doing the update but not after. Much appreciated, huge hassle avoided.
