Orbi WiFi 7 RBE973
Reply
Orb RBR40 Router won't connect to Windows 10 desktop
jcampagna42
Follower
I have 2 satellites connected to the router. The router is connected to an AT&T modem. Problems with slow internet started a few days ago. Found that some of the devices were assigned to a satellite farther away. Tried to reassign some devices, but still slow speeds. 2 questions:
1. All devices (phones, tablets, printers) are connected to Orbi, except for a Windows 10 desktop. Can't connect to the network is the error message. Not sure why this happened now. Have had the Orbi at least a year.
2. Should some devises be assigned to the router, if they are close to the router? I assume devices should run off whichever satellite is closer.
Message 1 of 3
Guru
Re: Orb RBR40 Router won't connect to Windows 10 desktop
Be sure the Windows 10 PC has updated network adapter drivers from the adapter mfr.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
Message 2 of 3
Mikey94025
Hero
Right-click on the Windows wireless connection and select Forget, then setup the wireless connection again.  It might be trying to reuse old info that has since changed so this is the best way to reset and connection again.  If that doesn't work, run Windows Update and make sure your wireless network drivers are up-to-date.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 361 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
