Reply
Orbi 2200 ip address
Gulfstream1
Follower
Just received my Orbi wifi system with three satellites to cover my house.  After setting it up I was unable to connect using the Orbi app and the main router had a solid Magenta light.  I called tech support and spoke to a nice gentlemen in India who spend 30 minutes trying to figure out the problem finally after screensharing and looking into my modem he concluded it was an IP problem and that the only solution was to buy security software offered by NETGEAR for $200 a year or $800 for a lifetime to make the system work.  He said there was a problme with the ip address between orbi and my modem.  Any insight would be helpful
Model: RBK22| Orbi AC2200 Tri-band WiFi System
Message 1 of 3
Guru
Re: Orbi 2200 ip address
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 3
Blanca_O
NETGEAR Moderator
Hi @Gulfstream1
May I know the number you called to reach support team?
Blanca
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 582 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
